P4 stainless strip
david
P4 stainless strip
Post by david » Sat Oct 23, 2010 12:38 am
Just a quick question. I have new clips and rivets for affixing the stainless side strip to a P4.
How do I do this? Is it necessary to remove the door trim to gain access to the other side in order to fix the rivets?
Many thanks,
David Hollister.
Re: P4 stainless strip
Post by 47p2 » Sat Oct 23, 2010 9:04 am
The rivet heads go to the outside so no you don't need to remove the door card
Post by Phil - Nottingham » Sat Oct 23, 2010 10:20 am
The rivets used are "Pop" rivets (in alloy) for which a special had gun/pliers are used - self tappers can be used but corrison is is likely unless stainless is used and the holes are likely to be too big
