Thermostat for P3
SA103
Thermostat for P3
Post by SA103 » Fri Oct 05, 2012 7:57 am
Has anyone had any experience with sourcing a new thermostat and possibly housing for P3 75 engine? What is the best option? I haven't actually tried to get the housing off yet and am unable to say what condition it is in.
Cheers
Adrian
Re: Thermostat for P3
Post by lakesrally » Fri Oct 05, 2012 10:09 am
I would try Mike Evans or Mike Couldry for both. Housing can be a pig to get off, should have a rubber ring underneath, I know these are available, in think I might even have a spare lying around in the garage somewhere. Best of luck.
SA103
Post by SA103 » Sat Oct 06, 2012 3:26 am
Thanks Stewart
I'll be careful with the housing then!
Adrian
Ray
Post by Ray » Sat Mar 07, 2020 1:54 pm
I see this is a very old post but somebody might be able to help because I also have to remove and refit the thermostat housing on my P3. (again)
The first time I did this it leaked from the seal between the thermostat housing and the water pump.
The seal does not seem to be sufficiently compressed to make a water tight joint.
Please advise,
Ray Lilly
Post by 47p2 » Sat Mar 07, 2020 9:26 pm
Contact Mike Evans and he'll sort you out
Dkenner
Post by Dkenner » Mon Apr 13, 2020 2:13 am
Given this is the same issue/motor that 1.6 and 2l Land-Rovers have, this rubber o-ring and copper insert are widely available from Land-Rover parts houses. Part no's 09170 and 09197
Dixon Kenner
1950, 51, 52 Land-Rover, 1976 101FC
