Tool tray
SNOBHILL39
Tool tray
Post by SNOBHILL39 » Sun Jun 03, 2012 6:26 pm
I have an almost empty tool tray in my 12 tourer, has anyone got a picture of what should be there and any of the tools to sell.
Gerry F capon
Re: Tool tray
Post by 47p2 » Sun Jun 03, 2012 8:47 pm
This is from the 1947 export brochure
SNOBHILL39
Re: Tool tray
Post by SNOBHILL39 » Mon Jun 04, 2012 9:16 am
Thanks for the picture, now need to find the correct tools. I have the adjustable, a couple of whitworth spanners and the "T" bar, but I don't know if they are original.
Regards,
Gerry
Gerry F capon
kartik
Re: Tool tray
Post by kartik » Tue Jun 05, 2012 1:31 pm
Did the P3 also come with tool trays like the one shown above ?
P3Steve
Re: Tool tray
Post by P3Steve » Tue Jun 05, 2012 1:46 pm
Yes the P3 had a tool tray, not the same shape but most of the tools look like there the same or very similar
SNOBHILL39
Re: Tool tray
Post by SNOBHILL39 » Sat Jun 09, 2012 9:26 am
Do these tools ever come available to buy at any time, I would like a good original set.
Gerry F capon
Re: Tool tray
Post by 47p2 » Sat Jun 09, 2012 6:34 pm
You do see them on ebay now and again, but how complete and original is anyones guess
mark
Re: Tool tray
Post by mark » Mon Jun 18, 2012 3:47 pm
There were 2 double open ended spanners with "Rover" embossed on one side on ebay last week, one went for £18 the other for £3.
I have 4 different spanners, 3 double and one single open ended but I think there may be more with different combinations for various trays.
My 1937 10 does not have a tray but the parts lists says that I should only have 3 spanners in total.
Before you go buying all of them I should find out from your model's parts list which ones you should have unless you pick them up cheaply.
Mark
SNOBHILL39
Re: Tool tray
Post by SNOBHILL39 » Wed Jun 20, 2012 4:24 pm
Thank's Mark,
I keep looking but not too sure what I am looking for, I have not seen a picture of the 12 tourer tool tray.
Regards,
Gerry
Gerry F capon
Re: Tool tray
Post by luli » Fri Jun 22, 2012 8:13 am
The master parts catalog has a 12 h.p. tourer supplement. The following appers on it's first page:
"GENERAL EXPLANATION
The 1947 12 h.p. Tourer body is mounted on a standard 12 h.p. Saloon chassis, and the majority of the spare parts are therefore the same as those required for the Saloon model. This supplement details the few differences involved and also shows the parts required which are peculiar to the Tourer
pattern body.
All the items concerned are correlated to the text of the 1939-47 Master Spares List by quoting page and plate reference numbers of equivalent parts. They fall into three categories, as shown in the remarks column on each page :—
1. Additional. Part used on the Tourer model and not on the Saloon.
2. Replaces. The part number shown in the supplement for the Tourer takes the place of
that shown for the Saloon in the main list.
3. Not required. Part used on the Saloon model and not on the Tourer."
Since the tools section is not mentioned in the supplement I conclud that the tools are not different from other 39 - 47 cars tools. Here are the tools which are mentioned in that section:
TOOLS
Starting handle complete 1 07383 1Oh.P.
Starting handle complete 04971 Except 10 h.p.
Wheel brace 50217
Lifting jack 07685 10 and 12 h.p.
Bevelift jack 50268 14, 16 and 20 h.p.
*Combination pliers 2703
*Screwdriver 5" 2704
*Double end spanner (1/16" x1/4") 2705
*Double end spanner (5/16" x 7/16") 2706
*Adjustable spanner 6" 2707
Tyre pump 233283
*Distributor screwdriver and feeler 3412
*Single end spanner 3/8" 2712
*Sparking plug spanner 58296
*Tommy bar 1403
*Spanner for freewheel cable adjuster 57220
*Box spanner 52485
*Tappet clearance feeler 05879
*Tyre pressure gauge 05321
*Extractor for Schrader valves 05557
Luggage strap 44" long 73481
Luggage strap 40" long 3 68712
Luggage strap 9" long 2 68713
Rubber bands for luggage strap ... .... 2 69770
*Budget lock key 1 64245
I have marked with * the tools tray items.
Regards,
