Diff bump stop
P3Steve
Diff bump stop
Post by P3Steve » Sat Aug 28, 2010 8:27 pm
While giving the prop shaft UJ's a good greasing I noticed that the diff bump stop had gone and all that's left is a small round plate with a stud that goes through to the area under the seat base, this looks like an old mini exhaust bobbin with out the rubber on it. now I could get another bobbin and cut off one end but has any one found a local alternative off the shelf from a local modern dealer that might be a bit more heavy duty?
P3Steve
Re: Diff bump stop
Post by P3Steve » Mon Sep 20, 2010 8:17 am
Had a root around in a friends garage and found a nice exhaust mounting that when one end was cut off made an ideal bump stop.
