Starting Problems
AFPU
Starting Problems
Post by AFPU » Wed Apr 22, 2026 6:00 pm
On a recent trip out our 1937 Rover 12 Sports Saloon played up a little on the way back, coughing and spluttering and down on power, so we had to stop a few times to try and diagnose the problem, but to no avail. However, she did eventually clear herself and we made it back OK.
I suspected it may be dirt in the fuel and indeed the fuel filter was an old plastic type one and showing that it had indeed collected some stuff. I therefore, replaced that with a new glass one and also checked the fuel pump filter, which was clean, and fitted new spark plugs.
She started up straight away, as she always has done, and I promptly got ready for a test drive to see if she was still a little hesitant. However, after leaving her to warm up I came out to find she had stopped…….and she now will not restart (turns over but does not fire). Upon checking the float bowl it was not full and so I thought maybe she had run out of fuel, despite the fuel gauge reading a quarter of a tank. So more fuel in, but still not desire to fire.
So any ideas on what might be going on and perhaps where to check next?
The car has electronic ignition so I am assuming that is not the cause.
And a quick question, reference the jet adjusting nut on the SU carb, which direction weakens the mixture, clockwise (screwing it in) or anti-clockwise (screwing it out)?
AFPU
Re: Starting Problems
Post by AFPU » Thu Apr 23, 2026 3:30 pm
OK, the problem seems to have solved itself after establishing that it was lack of fuel feed from the tank as the car started and ran OK with the float bowl filled, but the fuel pump was still dry.
So having worked back to where the rubber fuel pipe connected to the metal feed line, I blew through the line and also rodded it with wire back as far as I could. Now she starts and runs OK but I am still nervous about what caused it and presumably there is still the treat that it will happen again and maybe not in the driveway this time!
So next task is to try and blow the metal fuel line through from the tank end, but am not sure where best to get access. Any ideas?
Post by SHyslop » Fri Apr 24, 2026 12:40 am
Turning the nut up, ie to the right, weakens the mixture, the reverse being true for enriching.it.
On the 37 car you have, I am presuming you have an access hatch in the boot floor to the fuel pipe pick up. Have you an electric reserve or a mechanical tap at the back for it? Either way it should be easy ish to disconnect the fuel pipe at the tank end to blow through it. However, you also need to blow through the tank pick up unit, both pipes. The likely culprits are large pieces of debris which have gathered in the bottom of the tank. The suction pulls them to the pick up pipe, they get pulled to it , stay there then fall off when the suction stops. It can be worthwhile to drain the tank through the plug on the bottom ,filter the petrol, refill with a gallon, drive a little, repeat the process. In extreme cases, remove the tank, clean out as far as possible, remove the sender unit and pick up pipe and fill with POR tank sealer from Frost. This will seal in any loose pieces of rubbish you cannot otherwise remove and also stop other rust from dropping down into the fuel. Fitting a cheap inline filter can be a good idea, especially if you have a piece of rubber pipe in the system already. The earlier cars do not seem to have had a gauze round the delivery pipes in the tank but the later cars do. Fitting a gauze to the earlier cars with the push pull tap can be done with a small gauze but it is a bit finicky as the diameter of the pipe hole is rather small, compared with the later cars.
Only personally, I do not share your faith in electronic ignition units. I reckon they work reliably until they fail. I would carry a baseplate with a condenser and points ready to fit if required as a back up. In our local club, we have had a couple of occasions where this has happened and the heads cluster round the open bonnet looking at the black box which has suddenly failed to work, with no unit handy to swap 40 miles or more from home in the middle of nowhere.
However, given you have what you have, it is my belief that people fit electronic ignition without necessarily having fully explored the many potential minor failings in the rest of the ignition circuit which can all conspire to fail enough to produce poor running or non running. The electronic module may remove a worn condenser and worn points but the weak areas in the DK distributor, if that is what your car has, can start with a failing coil - possibly overheated at some previous time, poor HT leads or a poor LT lead , broken insulation in the system somewhere, such as baseplate cracks, cap cracks, rotor arm failings (particularly with riveted arms) and also potentially whether you have a plug lead cover fitted or not. Also check for sideways play in the distributor shaft due to potentially worn bushes.
It can be worthwhile running the engine in the dark and looking to see whether there are any signs of sparking visible, where something is jumping to earth. The later distributors - post war type DKY - can be worse than the prewar ones because of the plastic insulator pieces which insulate the 12v supply to the unit. These crack or disintegrate with time.
There are useful little gadgets available for testing spark intensity, such as this at £4 - nothing fancier or more expensive required :
https://www.ebay.co.uk/itm/146652796933 ... BM9JjV57dn
It adjusts so you can see how far the spark will jump, not just that there is a spark. I have one hooked up to a test distributor run by a lathe and it finally enabled me to have a clear out of poorly operating coils which were shown to be deficient compared to others. You can also test the other components by substitution running them up to decent speeds.
It is worth remembering that annual servicing used to include throwing out the cap, points, condenser, and rotor arm each year to be replaced with new. I have to confess to just having replaced a condenser I previously replaced 14 years ago, after about 5000 miles.
Just going back to the coil a second, it could be worth checking what the maximum voltage in your charging circuit is. Although the amperage going in may appear normal, I am aware of too high a voltage in the system - over about 14.4/ 14.7 or so - potentially having a detrimental effect on an already tired coil. Just some things to maybe try over the weekend !
Riley
Post by Riley » Fri Apr 24, 2026 12:36 pm
It still sounds like a fuel supply issue to me, especially if the float bowl wasn’t full. I’d check whether the pump is consistently delivering fuel to the carb and make sure there isn’t any blockage further up the line.
For the SU carb, screwing the jet adjusting nut up (clockwise/in) weakens the mixture, while down (anti-clockwise/out) enriches it. Hopefully it’s something simple and she’ll be back running soon.
rgburlend
Post by rgburlend » Mon Apr 27, 2026 3:31 pm
I would leave the carburettor jet adjustment nut alone, this is not the cause of your starting problems. That nut will make some slight adjustment to the mixture to ensure smooth idling, it will not change fundamentally the air fuel mixture for the rest of the rev range, that is done by changing the needle. Rover will have done their work to select the best needle at the time, which of course might not be the ideal needle for modern petrol but it won't be far off.
I would suspect a blockage in the fuel delivery pipe, disconnect the petrol pipe where it enters the tank and attach a piece of tubing to it, then blow using compressed air along the pipe from the pump to the tank, then check that the pipe from the pump to the carburettor is also clear. As a precaution, I would blow both ways as I have had an instance when a rubber fuel pipe was disintegrating internally and a small flap of rubber was acting as a valve preventing adequate flow to the carburettor.
Its probably also worth removing the main/reserve valve from the tank and ensuring that it is operating correctly and is clean.
AFPU
Post by AFPU » Tue May 05, 2026 3:00 pm
Thanks for all the responses and having blown through the fuel lines and checked the carb it turns out it must be the fuel pump.
So now I am awaiting delivery of a repair kit for the AC Type T pump. That will then hopefully cure the problem as she starts with the float bowl full, so everything from then on is OK.
AFPU
Post by AFPU » Thu May 07, 2026 6:48 pm
The AC Type T Fuel Pump has been rebuilt with an ethanol resistant diaphram and fitted.
She now starts up fine and runs well, but when I take her out for a test drive she is still under powered, pops and bangs but will occasionally run OK but then back to below par again.
Having done everything on the fuel side and fitted new HT leads and spark plugs I am at a bit of a loss. However, when checking over the ignition side I noticed that the distributor body rotates slightly and is not held firmly by the clam and tightening it up does not improve things. So a couple of questions, bearing in mind she is fitted with electronic ignition:
1) Could the fact that the distributor body rotates slightly be the cause of the poor running?
2) How best to remove the distributor?
3) What should the correct clamp look like and where does it anchor?
Post by SHyslop » Sun May 10, 2026 10:35 pm
Before touching on your three questions , from what you've said, the symptoms you describe do sound like two things (in reverse order of likelihood !):
1) a sticking piston in the carburettor. I had two P2s, a 12 and a 14, which both suffered from this and they were a bit of a bother but my current batch are rather better, I am pleased to say. The problem is that because the downdraught SU has the piston on its side, it does not wear equally in the same way that a sidedraught SU does and eventually it can stick at the "closed" position because the depression to draw it up has to counteract SUs strongest spring and a minute spot that is just catching. Take off the air cleaner and see if the piston catches at its bottom travel. It could also catch on the jet. Should it be this, I have found that using air tool oil as the lubricant can help with the former and obviously adjusting the jet with the latter. The piston can stick when warm in a way it doesn't when cold, the clearance being very small.
2) sticking valves. If your car has not been run for some time, this is a possibility. The oil supply to the rockers on these is not (I think) as copious as some other makes which is one possibility but also old oil and a lack of decoking , especially if the car has been started occasionally, run on the choke and not really gone far, which will result in gummy/sooty deposits on the valve stems which can only really be removed by taking them out and (power) wire brushing them. At slow speeds they may be managing but, as the handbooks say, banging occurs when an unexploded charge of fuel is somewhere at the wrong time and sticking exhaust valves is a prime cause.
As for the distributor, I have been out and had a look. Does your distributor have centrifugal advance or is it fitted with a control on the wheel for advance and retard ? (That will have a bearing on your second and third questions) I suspect the former in 37 but If the latter, there will be some "slop". There should be less - minimal - with a micrometer adjustment but I wouldn't say they are the rock solid fitment as used on some other makes. I can take some photos if you describe what you have. I see I have already written my views on electronic ignition so shall not bore you further.
AFPU
Post by AFPU » Mon May 11, 2026 5:34 pm
SHyslop, to answer your questions:
1) I had previously checked the carburettor and all seemed to be OK with the operation of the piston, so I don't think it is that; but worth another check. When I was checking the mixture setting the piston was falling back OK and no catching anywhere.
2) As for sticking valves, after everything else failed to address the running issues I had thought it could be that; so I'll check.
As for the distributor, this is fitted with the little control wheel for advance and retard, but after some responses on the Facebook page for P3 and Running Board Rover, I am not sure that this is again the source of the issue.
A friend who is very familiar with pre-war cars coming over one day this week to help me resolve the issue and no doubt we will be running through the points you raised and hopefully gettng to the bottom of the problem.
Post by SHyslop » Tue May 12, 2026 3:00 pm
I was just thinking about your car as I carry out a rewire , plenty of time to think ! If you hadn't said that the car was going all right at times I would have suggested the plug lead order. 1243 is a slightly unusual order, used by Riley and Rover, whereas 1342 was used on Austin, Morris,Alvis and others. I thought it worth mentioning in case someone comes new to all this, reads back these messages and still wonders what the problem could be.
20th May : I have been having a look at my 1947 12, which has always been a bit of a poor goer compared to the other 12s. However, that appears to have been cured. Firstly, changing the Solex carburettor for a prewar SU . Secondly, I had mentioned before about the distributor not being as rock solid as the others. I took it out and decided that the problem lay with the distributor itself. I rebuilt its innards into a new body with new bushes and, having just assembled it all in a "close to" setting of the rotor arm compared to where the old one had been, the car started immediately and ran well - better than it has done I think in all the time I have owned it, 11 years or so. Wear in the shaft or bearings is something electronic ignition does nothing about though whether it is more tolerant , I don't know.
