1934 Rover 12
1934 Rover 12
Does anyone know what the tracking setting is on a 1934/35 Rover 12 Ive looked through the manual and can`t find any mention of it Len
Re: 1934 Rover 12
"1/16 for all beam exle models" Watson "Rover cars 1934 - 1962" page 187.
Re: 1934 Rover 12
Thanks very much I have the Rover workshop manual 1934 -47 models and I`ve searched through it without any luck Len
Re: 1934 Rover 12
Hello thanks for the information on tracking .As a matter of coincidence Ive just received all the history of the car and in it was the Rover cars by V.H.Watson.However on page 187 it says,that all beam axle cars should be 1/16 inch not 1/4 inch Which is which ,since you seem to be the man who knows Also it says the clutch was rebuilt in 2014 since which it hardly done any miles.But the clutch only bites when the pedal is almost fully out,and the play is correct if not a bit high at 35mm. Len
Re: 1934 Rover 12
Could you please confirm the correct amount of toe in.I ve booked the car in next week to have it checked.I dont know if the garage would have data for a 1934 car Len
Re: 1934 Rover 12
Sorry for my error. I have corrected it.
Re: 1934 Rover 12
Thanks for letting confirming the correct toe in.Is it worth having the caster angle checked at the same time,or is this fixed on the 1934 Rover 12s Len
