Tappets
wooster
Tappets
Post by wooster » Sun Apr 05, 2015 10:45 am
Just about to have a go at the tappet clearance on my 14. Never used a set of feeler gauges in my life! Two questions;
1. I know (from my excellent new workshop manual) that it should be done when the engine is hot but that's not possible. Is it OK to do it from cold and then redo it when I am able to get the engine started and up to temperature?
2. How do I find out if my engine is group 1 or group 2? Manual mentions black and red plate on the rocker cover. I can't see any plate on mine.
Thanks gents
Cheers
Rich
_______
'39 P2 '14' six-light
1938 P2 14
Re: Tappets
Post by 1938 P2 14 » Sun Apr 05, 2015 11:33 am
A few pointers, have you done work on the engine? how is the compression, as you have never done tappets before do you know the process, valve clearances vary from .005-.010 hot but no harm in seeing what they are cold it will see if there is a variation. If the engine is standard I personally give the clearances about .002 more clearance to protect from the affects of unleaded fuel. Any more questions?
Regards Iain
Re: Tappets
Post by luli » Sun Apr 05, 2015 12:09 pm
1. Yes, you can do a preliminary adjustment when the engine is cold. Some advice: Use the starting handle to turn the engine. Removing the spark plugs will considerably ease that operation. Also, have you checked the condition of the rocker shaft and tappets? see more about it here: http://wp.me/pXLKy-1x3 and here : http://wp.me/pXLKy-1yB
2. If the dynamo is driven by a belt, then it is a group 2 14.
MikeB
Re: Tappets
Post by MikeB » Sun Apr 05, 2015 5:30 pm
Hi
Just another note, when adjusting valve clearances hot or cold use the rule of nine IE when no 1 exahust valve is open you adjust exhaust valve number eight
And the same for the rest, two open adjust seven etc.
1938 P2 14
Re: Tappets
Post by 1938 P2 14 » Sun Apr 05, 2015 6:29 pm
You can't use the rule of nine on a six cylinder engine
wooster
Re: Tappets
Post by wooster » Sun Apr 05, 2015 6:30 pm
Thanks gents. Wish me luck.
Cheers
Rich
_______
Chris C
Re: Tappets
Post by Chris C » Sun Apr 05, 2015 8:00 pm
Correct, Rule of 9 is only for 4 cyl engine, you use Rule of 13 for 6 cyl engine:
The “Rule of 13″ is a way to know which valve to adjust on a 6 cylinder engine.
If 1 and 3 are open, 1 + 12 = 13 and 3 + 10 = 13. Thus 12 and 10 are the valves to adjust.
Rover Sport Register
1939 - Rover 14 Saloon (P2)
1975 - Rover 2200 Saloon (P6)
1938 P2 14
Re: Tappets
Post by 1938 P2 14 » Sun Apr 05, 2015 8:27 pm
We all learn from each other that is why this is such a good forum for all abilities.
Re: Tappets
Post by GOY189 » Sun Apr 05, 2015 10:25 pm
39 14 hp has a group 2 engine, so tappets should be set to 10 thou hot.
