Petrol tank reserve valve 1939 10HP
peter rimes
Post by peter rimes » Mon Mar 03, 2014 6:00 pm
Hello. Nearly there with this restoration . I find the change over valve is not functioning on tank and a continuity test to coil suggests an open circuit.
Has anyone repaired this unit or if I cannot obtain part will it default to work without electrical energising of coil?
Re: Petrol tank reserve valve 1939 10HP
Post by luli » Mon Mar 03, 2014 6:28 pm
I did. You can read about it here: http://wp.me/pXLKy-iO and here: http://wp.me/pXLKy-1nF. I gave the solenoid coil to a local shop for re-winding: this is a simple operation.
Some leaks had been detected using a hand-held vacuum pump, and cured with Loxeel. Without rectifing the leaks vapour locks can be expected.
Read also here:
http://www.fourashesgarage.co.uk/index. ... &cID=23004
and here:
http://www.dlcentre.com/forum/topic.asp?TOPIC_ID=14943
