Lucas distributor type for model 100 - 1960
ThomasMoRo
Post by ThomasMoRo » Fri Mar 06, 2026 1:39 pm
Does anyone have a spare parts catalog that also includes the 1960 Type 100?
I'm looking for the number of the matching Lucas distributor!
My data only goes up to 1959 and doesn't include the Model 100.
distributor list for model and part number.jpg (60.49 KiB) Viewed 46652 times
PS: My plan is to use an electronic distributor from 123Ignition, and I need some data for that.
Re: Lucas distributor type for model 100 - 1960
Post by GOY189 » Fri Mar 06, 2026 5:46 pm
It would appear to be Rover P4 95 & 100 Distributor type DMBZ6A reference 40613D from Ignition car parts advert on Ebay:- 146121556706
"Genuine Lucas DMBZ6A 40613D fully reconditioned in the UK
Sold on exchange basis, there is a £80 refundable surcharge included in the listing price which will be refunded when we recieve the exchange unit.
This distributor can be converted to electronic ignition for an additional £40
ROVER - P4 2.6 6Cly 90 / 100 / 105R / 105S) Jan 1956 to Jan 1964 2639 IOE
Ignition car parts Ltd are one of the largest suppliers of used car parts in the UK we have a full range of car parts for classic and modern vehicles. We have a full range of new Reconditioned and used distributors, we also offer a test repair and rebuild service for any distributor.
Not sure if your distributor is faulty? we can test it for you, we do this free just pay the postage back, if faulty we can repair it, it's cheaper than buying a new one.
Please contact us it you cannot find the part you need for your car.
Please send us your registration number and car details if you are not sure this part fits your car
We are here to help any advise you need please contact us it cost nothing to ask
Full details can be found www.ignitioncarparts.co.uk"
The RSR's usual disclaimer applies.
Post by SHyslop » Sat Mar 07, 2026 11:38 am
Dear Thomas,
Regarding 123 distributors. This is just a suggestion. I have only had one 123 distributor and strangely enough, I bought it for a Volvo 123GT. The car seemed a bit lethargic to me coming from Triumphs and Rovers and I suspected an ignition fault that was eluding me. However, I can truthfully say that despite the eye watering amount of money the distributor cost, it made not a bit of difference.
Over the years, that and other experiences have lead me to look carefully at ignition components. If we know that a car with mechanical components and simple electrics worked reliably in the past, there is no reason why it should not do so today. Without wanting to write too much, I have found that cracked or broken plastic insulating components are a common source of problems, as are ill fitting or poorly aligned contact points, poor HT leads (broken wires just inside the insulation where they bend - modern copper does not bend much before it breaks), poor LT connections, distributor arms with rivets, cheap condensers. Finally, I have been testing coils and find considerable differences in the spark potential across various models. These can be tested with one of these :
https://www.ebay.co.uk/itm/285412114507
Spark plugs can also be simply tested and compared with one of these:
https://www.ebay.co.uk/itm/167460362892
I've also found that it isn't that one product doesn't work but, when tested, it doesn't work as well as another. I appreciate you may have been down this route already so do excuse the suggestion if you have exhausted all other avenues.
I am not saying that electronic ignition isn't worth it. I would question, though, whether a very similar result cannot be obtained through close examination of the relatively few simple components that make up electro mechanical ignition. There were plenty of Rovers mentioned by RSR members in the 50s/60s which had done over 200,000 miles , all on conventional components.
