1937 P2 Front Seats
AFPU
1937 P2 Front Seats
Post by AFPU » Sat Nov 29, 2025 11:45 am
Hi All.
Having just acquired my 1937 Rover 12 Sports Saloon I have been checking her over to identify any areas where I might want to make some inprovements. One area is the drivers side front seat.
So are the front seat cushions removable separately (i.e. without removing the whole seat/frame) as my drivers side cushion could do with being a bit firmer?
Re: 1937 P2 Front Seats
Post by SHyslop » Sat Nov 29, 2025 11:04 pm
The cushion should just pull straight out. This is usually the most worn piece of upholstery in the car. I've had quite a few recovered but if the leather is intact, it should be a straightforward job to repack it with firmer stuffing. If it is tight to pull out from the seat, lift it up at the front first and it should pull up, refit from the back first.
AFPU
Post by AFPU » Sun Nov 30, 2025 3:59 pm
Many thanks. The leather is in great condition, so probably just needs a bit of packing adding to firm it up.
