12hp Tourer #110 (the blue one)
Post by David2021 » Fri Feb 07, 2025 10:28 am
Well the new electronic regulator seems to have restored charge to the battery! Easy to fit & uses my old cover, so looks right. I took the opportunity to restore the fuses to more realistic levels (NOT 50 amps on everything!)
I'll give it a good run next week to see if my coil overheating/condenser change has also worked. Meanwhile I have done the old Rally trick of having the other coil all wired up ready to swap over....
The fuel reserve changeover wiring has been located and works, so that will also be fitted …fingers crossed the expense will be worth it !
Re: 12hp Tourer #110 (the blue one)
Post by David2021 » Tue Apr 01, 2025 9:27 pm
At last the reserve fuel changeover is in , fitted and working 😀😀😀
Amazing how awkward it was for such a relatively simple job! Even the four mounting screws fought back!
But it clicks over and changes… on the reserve setting quite a bit of crud ended up in the pre carb filter… better look at the one on the pump…
Found that the o/s tank mounting bolts had loosened a bit from when the tank came out a couple of years ago, despite self locking nuts, the mounting pads I think had compressed a bit. Better look at the other side!
Post by SHyslop » Tue Apr 01, 2025 11:24 pm
From what you said, I wondered if you had the gauze in place round the pick up pipe ends ? I've found that if it's missing the pipes can block long before it reaches filters further down the line. The surface area of the original gauze means that enough mesh should remain clear to keep the petrol flowing.
I don't mean that to sound as if the tank is absolutely full of debris but sometimes filling a tank full that has maybe not been full for 20 years or so dislodges bits from the top. Of course, removing the tank is the only way to really clean them out but life is short and that can be a job left to "another time".
I had this problem with the 38 14 but on a test run of 13 miles this morning it performed perfectly and I had a thoroughly enjoyable time out in the sunshine. It has taken a couple of years to reach this reasonably happy place!
Post by David2021 » Thu Apr 03, 2025 9:24 am
The pick-up pipes/solenoid unit I have replaced only had one pipe fitted! My replacement has good wire mesh basket
You are ,of course, right about rubbish sloshing about,but I had this tank off to clean &seal it before w went to Germany a couple of years ago,
All I have to do now is put some miles on it to make sure the new electronic regulator is doing its job and that the coil no longer overheats because the condenser was faulty!
Post by David2021 » Thu Jun 05, 2025 9:30 am
For any variety of reasons I haven’t been able to give the char a decent run, but have used it for running around in without problem…
However… yesterday I fixed a problem with the fuel tank sender (leaky float) and did a 5 mile trip to collect the paper.
The car seemed a bit flat & missed a couple of times and died 100m from home!
It did not want to start,but managed a couple of neighbour frightening backfires😱
The coil was really hot…..aargh
As I was causing difficulty in the lane a neighbour towed me home where I swapped coils, but this didn’t work & I ran out of time and enthusiasm.
So, no problem with fuel, plent at the carb, I’ll check the spark and see if it will run if I can later today.
I know the distributor should be basically ok and unworn (it is a NOS B90, with a replacement condenser after previous similar issues last year that were suggested to be condenser related.
Is anyone running electronic ignition on a post war P2 twelve? Not necessarily a complete distributor, but possibly a module?
The car is negative earth.
Post by TonyG » Thu Jun 26, 2025 8:02 pm
Hi David,
Have you got your car running properly again and, if so, what was the problem?
Reading through your recent posts, the poor running problem sounded slightly familiar to an issue I recently had with my 12 Saloon. Moving it out of the garage to give it a once over before a show, I was annoyed to discover it popping and mis-firing. It had been perfect a week or so before when I’d parked it there! Things improved a little once the engine was warm but clearly not ‘sewing machine’ smooth as usual. Taking each plug off in-turn revealed that No4 made less difference so I changed the plug for a known good spare. Running much better but not right. Fortunately, it had very little petrol in it and I was able to add a couple of gallons of newly purchased E5. The change back to usual smooth running occurred soon after. I fitted a complete set of new plugs to be sure. A few days later I drove it 50 miles to Newmarket and 50 miles back without issue.
My conclusion to all this is that the fuel, although only a month or so old in the tank, had deteriorated and probably caused the spark plug to fail somehow. Modern Ethanol Unleaded has a very poor shelf life and our Rovers have an open vented tank, which possibly hastens it to go off. Also, this episode served to remind me that confusing problems are usually the result of a couple of things and rarely just one.
In your case, it might be worth draining the fuel and adding fresh petrol. The car will no doubt run better. As you have had condenser trouble, change this as well. Usually the old ones are better than modern after market ones. Cleaning the plugs is always worthwhile too and only takes 5 minutes.
Good luck and let us know the outcome.
Post by David2021 » Sun Jun 29, 2025 8:31 pm
Thanks for those hints Tony
Im looking at the cars later this week when back from Holland with the Magnette
I have an electronic ignition kit ready to fit
The fuel is pretty well fresh
I will report back!!!
Post by David2021 » Sun Jun 29, 2025 8:37 pm
Another thought
Reading the post from Luli about plugs… I have a set ready to fit, but will eliminate one thing at a time!
I will clean the current (quite new) ones!
Post by David2021 » Mon Jul 14, 2025 9:45 pm
failure at first attempt! No spark. Now the weather is a bit cooler I feel more inclined to try again!
Connected up as per instructions...I had to lengthen the wires from the unit on the distributor to reach the coil,,, A complication is that I have a "security" switch wired to the coil that allows the electric fuel pump to operate. This operates correctly!
I will re-check the wiring and also ensure that the Battery connections are clean...there was a post on tan Austin Seven site where the installer had exactly this problem (nothing out of the coil
& it was solved by cleaning the battery terminals! At the coil originally has I recall he was getting under 5.25v & after cleaning...6,25v. End of problem.
Post by David2021 » Mon Jul 14, 2025 9:51 pm
Failure at first attempt! No spark. Now the weather is a bit cooler I feel more inclined to try again!
Connected up as per instructions...I had to lengthen the wires from the unit on the distributor to reach the coil,,, A complication is that I have a "security" switch wired to the coil that allows the electric fuel pump to operate. This operates correctly and as it energises the coil it allows the pump to tick happily.!
I will re-check the wiring and also ensure that the Battery connections are clean...there was a post on an Austin Seven site where the installer had exactly this problem (nothing out of the king lead on the coil) & it was solved by cleaning the battery terminals! At the coil originally - as I recall - he was getting under 5.25v and after cleaning...6,25v. End of problem.
