P2 Brakes
AdrianGoodyear
P2 Brakes
Post by AdrianGoodyear » Tue Sep 10, 2024 9:30 am
Now into my second year of my (P2, 12hp, 6 light) restoration, I now turn my attention to the brakes....
Having dismantled everything prior to cleaning/repainting/replacing worn clevis pins etc, I find that there is a rod to the rear brakes that has a spring plunger device that (presumably) holds the rear brakes off unless the brakes are being applied. My issue is that the spring, stop and plunger seem to be seized and will not come apart. I have tried some tentative tapping to see if this will result in any movement but all seems to be firmly in place. I'm reluctant to try harder in case I damage parts I may find difficult to replace. Does any one have any experience of this and can, perhaps, advise?
Re: P2 Brakes
Post by TonyG » Wed Sep 11, 2024 5:45 pm
Hi Adrian,
You don’t say where this rod is located, but I’m guessing it’s the one that goes from the vertical swivel near the pedal box to the join where the handbrake connects? If so, I think this is the two piece rod that pushes backwards to operate the rear brakes. However, where one rod slides inside the other, there is a concertina rubber sleeve over the join. The purpose of this arrangement is so that the handbrake operation does not pull back on the rod going forward to the front brakes.
The rods can rust together and should be greased to prevent this and the rubber sleeve stops the water getting in. These are pretty robust rods so it is unlikely you will damage them. Suggest you apply liberal amounts of penetrating fluid before trying and if you cannot knock the outer off the inner (solid) rod, when held in a vice, then some heat might need be necessary. However, if they are impossible to get apart once some effort has been applied, you may need to source replacements but I doubt it will come to that.
I hope that helps and that I’ve understood the offending part correctly?
When I did my brakes, I had the shoes re-lined by Saftek in Cleckheaton. They turned them around in less than two weeks. I also found that slightly worn yolks could be drilled out and larger Clevis pins used or, where they were very worn, welded up and re-drilled to the original size. The biggest challenge is getting the front axle brake compensator to work without undue play and so it doesn’t foul on the leaf spring.
The braking system is all pretty simple and straight forward. Good luck!
AdrianGoodyear
Re: P2 Brakes
Post by AdrianGoodyear » Wed Sep 11, 2024 8:14 pm
Hi Tony
Many thanks for your response. Now you have assured me that they should come apart I will be more determined in my efforts - I'll give it a go tomorrow and report back. Thanks also for the gen. re the clevis pins - but that'll come later. Stay tuned!
Best wishes, Adrian
AdrianGoodyear
Re: P2 Brakes
Post by AdrianGoodyear » Wed Sep 18, 2024 5:44 pm
Hi Tony
An update.
I took a large hammer and a drift and attacked the offending item with renewed vigour. It has moved about 1/4" and I can now rotate the Sliding rod about 30 degrees. This is real progress! I have (re)applied WD40 and Plusgas and will now leave it to soak for a few days.
TTFN, Adrian
AdrianGoodyear
Re: P2 Brakes
Post by AdrianGoodyear » Sat Sep 21, 2024 6:59 pm
Hi Tony
At last it's free! So, many thanks for you advice.
Best wishes, Adrian
PSavage
Re: P2 Brakes
Post by PSavage » Fri Jul 18, 2025 11:51 pm
Hi I am rebuilding my 1947 P2 and just found out that the rear brake compensator should move. Mine is stuck fast, I have soaked it in penetrating fluid but :?: stupid question but before I attack it with greater force which end moves? ie which end is the 'inner' tube, the end nearest the spring end or the other end? Thanks Phil
Re: P2 Brakes
Post by TonyG » Tue Jul 22, 2025 6:30 pm
Hi Phil,
If the ‘47 P2 is the same as my ‘37 P2 I believe the rear brake compensator mounted on the rear axle swivels in two planes. I.e the whole thing moves in the vertical plane where it mounts into the axel and bit where the brake rods attach swivel in the horizontal plane. This takes account of axel moving up and down different amounts on each side of the car.
The whole lot needs to be well greased along with all the Clevis pins and yolks throughout the braking system. I think there maybe a Luvax connection on the rear compensator, which may explain why yours has seized so badly.
Hope that helps. I’m in Essex if it would help to look at the brakes on my cars?
Re: P2 Brakes
Post by TonyG » Wed Jul 23, 2025 7:02 am
Hi Phil,
I’ve just re-read your question and I think you are asking about the telescopic rod that goes between the brake pedal and rear brakes, as discussed in my earlier reply at the beginning of this thread from last year.
Once removed, this rod slides within the outer and, from memory, I believe the inner part goes at the front, connecting to the pedal. I’m pretty sure this is shown in the parts book diagram which, together with the workshop manual, are invaluable to all of us. If you have yet to get one, they are available via the club site.
The rear brake compensator is, as I previously described, mounted on the rear axle.
I hope this helps and my apologies for any misunderstanding!
PSavage
Re: P2 Brakes
Post by PSavage » Mon Sep 15, 2025 4:57 pm
Hi Tony, Thanks for the info. it did finally come apart after a grear deal of effort and now cleaned up slides very freely. One note though once apart there was absolutly no sign of any remenants of the spring!!
AdrianGoodyear
Re: P2 Brakes
Post by AdrianGoodyear » Sat Sep 20, 2025 5:38 pm
Hi
Just read your post.
I also had the same problem with the telescopic brake rod and also found no trace of the spring. However, once apart, I cleaned it up, loaded it with copious amounts of copper grease and all now seems to be working OK. The only issue now is that I don't know how much free travel there should be before the front brake starts to operate the rear brakes. I can reduce this to a very small amount by altering the set of the brake pedal and this, of course, is at the expense of reducing the travel on the brake pedal. I am not aware of the "correct" height of the the brake (and clutch) pedal.
So, I was wondering if you've had this issue and have any thoughts on the subject.
And of course, how's the rebuild going?
Good Luck, Adrian
