sunroof
lordrjwt
sunroof
Post by lordrjwt » Tue May 09, 2017 8:02 pm
Hi can anybody tell me the dimensions for the rear sunroof sheet metal please I have the RSR manual but cant find any dimensions any help appreciated
p3man451
Re: sunroof
Post by p3man451 » Fri May 26, 2017 12:55 pm
Mine is 1140 mm x 548mm,length measured over the curved section of Ash timber frame. There's a couple of 40mm wide strengtheners welded across width at 350 mm in from each end and a 50mm strip on the edge of the " Open " end for rigidity. Alan ( p3man451 ).
Re: sunroof
Post by GOY189 » Fri May 26, 2017 5:05 pm
Sunroofs were built to fit individual cars. The first job on the production line was to fit and adjust the sunroof frames to fit the aperture. They were then stamped with the body number and the body number plate was fixed to the car so the trimmed sunroof would be fitted to the right car. The dimensions of a Sports Saloon sunroof are different to the saloon sunroof.
lordrjwt
Re: sunroof
Post by lordrjwt » Mon May 29, 2017 7:57 pm
thank you both for your replies that's been a big help
