rear springs
wooster
rear springs
Post by wooster » Thu Oct 22, 2015 7:52 pm
Hi All
I have a saggy rear-end. But enough of my personal problems!
The back end of my '39 14 is looking a bit low. I guess the springs are starting to show their age. Is it simply a case of replacing them or is there an alternative fix?
Cheers
Rich
_______
'39 P2 '14' six-light
Re: rear springs
Post by 47p2 » Thu Oct 22, 2015 8:00 pm
The springs can be re-set to the correct height/tension if the leafs are in good condition. I had one done by Brost Forge many years ago and it is still fine to this day
Chris C
Re: rear springs
Post by Chris C » Fri Oct 23, 2015 7:55 am
Hi Rich, Not aware of anyone who offers this service in our local area, however I'll make a few enquires.
There may be a company at the Classic Resto Show @ Stoneleigh on Sunday (RSR have a Stand in Hall 2).
Normally there are companies at the NEC Classic Car Show who can retemper/reset road springs.
Rover Sport Register
1939 - Rover 14 Saloon (P2)
1975 - Rover 2200 Saloon (P6)
wooster
Re: rear springs
Post by wooster » Fri Oct 23, 2015 4:52 pm
Thanks Chris. I'm hoping to visit the NEC show next month.
Cheers
Rich
_______
Vince
Re: rear springs
Post by Vince » Mon Oct 26, 2015 8:50 am
Hi. Give these people a call. http://www.gbsprings.co.uk/heritage-car-springs/
They supply new springs to order but will reset your old ones too.
They have a good reputation in landrover circles.
Vince
Colin
Re: rear springs
Post by Colin » Thu Oct 29, 2015 8:13 pm
Is there any way of measuring if the rear springs need resetting? For example my bonnet slopes upwards towards the front, the front of the bonnet is about 1cm higher than the back. I would have thought it should be level! Does this mean my rear springs need attention?
Chris C
Re: rear springs
Post by Chris C » Thu Oct 29, 2015 10:16 pm
The latest edition of the P2 Workshop Manual has all of this information listed within it.
Re: rear springs
Post by luli » Fri Oct 30, 2015 9:32 am
Unfortunately, the workshop manual gives only the springs dimensions out of the car, not in situ . However, you need to remember that the Rover p2 suspension is under-slang, and a rear bonnet slightly lower than the front one is as it should be.
Colin
Re: rear springs
Post by Colin » Sat Oct 31, 2015 10:06 am
Okay thanks for the clarification Luli.
