Does anyone know what this jacking system consists of, looks like or even has a picture or information sheet?
Is it a fitted system similar to the Jackall hydraulic type fitted to numerous cars of the same period as the P2
D.W.S. Hydraulic Jack
- The Flying Dutchman
Re: D.W.S. Hydraulic Jack
Maybe this is of any use: http://www.mattboyd.org/cars/p3/tech/jacks/" target="_blank" target="_blank
Here the jack is first mentioned to be used:
Wraith 1938 - 1939.
The 25/30 Wraith continued with a 4 1/4 litre engine but the main difference was the fitting of independent front suspension controlled by coil springs. Road wheels were reduced from 19" on the 25/30 to 17". Built-in hydraulic jacks were operated by a hand-pump under the driver's seat. The Wraith was slightly heavier than it's predecessor but cruising between 60 and 70 mph was possible.
491 were made before events of 1939 stopped production.
Wraith 1938 - 1939.
Last edited by The Flying Dutchman on Tue Nov 25, 2008 11:15 pm, edited 1 time in total.
Job.
'73 P5B Saloon
'96 220 Coupe
'97 820Si
'96 Triumph Herald 12/50
'96 Triumph TR6
'73 P5B Saloon
'96 220 Coupe
'97 820Si
'96 Triumph TR6
I had read that article Job thank you, but I'm not sure that the Rover P2 set-up was the same.
Hopefully someone from the forum will be able to clarify this
I added/edited a bit.
Job.
'73 P5B Saloon
'96 220 Coupe
'97 820Si
'96 Triumph TR6
'73 P5B Saloon
'96 220 Coupe
'97 820Si
'96 Triumph TR6
