Selecting reverse is difficult
Re: Selecting reverse is difficult
Post by luli » Thu Aug 08, 2024 7:20 am
Even simpler than that: release nut 9 and turn it down few mm. Do the same with knob 8, and fasten. Now push of rod 11 will bring the disk 12 further down and problem solved.
Post by David2021 » Fri Aug 09, 2024 8:19 am
I think that is what I may have done accidentally!
I will fine tune it now.
In the handbook in answer to a complaint of difficulty to engage reverse,the answer given is to adjust the rod! But no details how to do it! The implication is that it is straightforward….apparently it is
Many thanks indeed…
Post by David2021 » Fri Aug 16, 2024 10:48 pm
I t is marginally better,so I will live with it! I don’t fancy removing/ dismantling the remote to get at the lock nut13! Unless I absolutely have to.
