Hi just joined register after purchase of 1948 p3 last week- now looking for exhaust gasket front pipe to manifold - my need a new manifold as one stud is broken- any thoughts please
deltee
						new member
Re: new member
Hi and welcome to the group.
Is the car a 60 (4 cylinder) or a 75 (6 cylinder)?
You can probably get the manifold gasket from John Davies tel:01724 784230. As regards the manifold, take it to an engineering company who can extract the broken stub. Many Land Rovers suffer from this and the usual mod is to replace the mild steel stud with a stainless steel replacement.
Hope that this helps
Re: new member
Hi GOY 189
Thanks for the info the car is at present with Heritage Classics for appraisal to determine what needs doing and in what order- they are going to try and extract the stud-if I need to I will use the contact you gave me for manifold gasket
Regards Deltee
Regards Deltee
