Pair P2 stepboards for saloon P2 FREE
Post by RobHomewood » Sun Oct 03, 2021 3:53 pm
I have recently replaced these as they do not quite fit the DHC, the inner curve is incorrect. They have been on the car for some years but they are not in bad condition apart from some lacy-ness at the rear end flange which I think should be repairable. Please note they do not come with the valances or any other accessories but are still covered in the rubber. The rubber is pretty well shot but it would take me too much work to remove it so the 'post and packing' will be hefty. These are therefore free to an RSR member but you will need to pay the P&P. Located in Cornwall so not easy to pick up!
First come first served before they go on the dreaded ebay.
For reference the rust evident in one pic on the underside of the outer edge is from the valance (removed) and is on the rubber not the stepboard flange underneath
paul williams
Re: Pair P2 stepboards for saloon P2 FREE
Post by paul williams » Sun Oct 03, 2021 8:57 pm
Hi Rob,
can I claim first refusal on these please. I am restoring a 1947 16 (saloon) which has no usable running boards so these if they fit, would be great. Is it possible you can measure them. My remnants measure 67inches long and 11 inches across the front wing.
Many thanks
Paul
Paul Williams
1929 2litre Saloon
1934 P1 10HP
1951 Rover Cyclops
1974 P6 3500
1998 LR Discovery I
Post by RobHomewood » Mon Oct 04, 2021 10:22 am
OK Paul you are first in the queue.
I will measure the stepboards shortly & let you know. I shall also weigh them.
Do you want to give me you email- I'm not sure how this is done privately but people seem to make it happen?
paul williams
Post by paul williams » Mon Oct 04, 2021 10:54 am
Rob,
thanks have sent you an email, if it doesnt turn up, just look at the contact details under my info by the side of this post, the email is there.
Paul
Paul Williams
1929 2litre Saloon
1934 P1 10HP
1951 Rover Cyclops
1974 P6 3500
1998 LR Discovery I
