Shock absorbers
Shock absorbers
Post by David2021 » Fri Jul 02, 2021 10:34 pm
I have the small, two vertical piston pattern fitted on my 1947 tourer. Without removing them I cannot see the identification numbers so I don't know if they are an original fitment, but certainly the O/S Front is leaky and passed its best. When new these shocks were valved to suit the end use, but in practice as long as the arms were right you could "get away with" a unit from a similar weight/performance car...Any advice?
Re: Shock absorbers
Post by luli » Sat Jul 03, 2021 11:30 am
I decided to give modern telescopic shock absorbents a chance. It is not an irreversible move. See details here:
https://wp.me/pXLKy-3EU
Re: Shock absorbers
Post by David2021 » Thu Jul 08, 2021 9:45 pm
Interesting Luli. Do you have any drawings for the dimensions of the brackets etc? No point in reinventing the wheel! I read many of your chapters yesterday via the Hebrew / English translation of course. I am intrigued that the "name" as translated for the Tourer comes through as "Terrorist"! I hope GCHQ is not tracking me! How do you get on with your Radial tyres? Do they stop the alarming "tramlining" when you find grooves or ridges (like white lines!)on the road surface?
Re: Shock absorbers
Post by luli » Fri Jul 09, 2021 7:54 am
Sometimes the machine translation is really embarrassing like when it translates "pin" to "penis" or "type" to "sex" but the main idea is retained. The carefully built steering and the radial tiers combination is really great, and tarmlining is hardly felt.
See this clip:
https://youtu.be/IYm7XEi50y0
Re: Shock absorbers
Post by David2021 » Fri Jul 09, 2021 10:27 pm
Thanks Luli. My tyres are pretty old and should be replaced before I do any serious motoring and Radials are perhaps the way to go. My steering is quite direct an no discernable play on joints and king pins (working lubrication system!...well lots of oil evident!)
Re: Shock absorbers
Post by GOY189 » Mon Jul 12, 2021 9:33 am
You may find that Stevson Motors www.stevsonmotors.co.uk can help with the Armstrong shockers.
Re: Shock absorbers
Post by David2021 » Tue Jul 13, 2021 9:48 am
Thank you Mike, I am familiar with Stevsons!
