1934 Rover 12 Dynamator
Has anyone fitted an alternator to a 1934 Rover,that has the barrel type regulator .Mine isn`t working even though there is O/P from the dynamo Im not sure about the wiring to this old reg.One article I read ,said just connect the wires from the old dynamo onto the replaced alternator ,but Im sure you remove the regulator wiring Len
- DSCF0269.JPG (162.71 KiB) Viewed 30811 times
Re: 1934 Rover 12 Dynamator
The alternator has its built in regulator, therefore the type of dynamo regulator existing is not relevant. The moment you have an alternator your existing regulator does not matter.
Thanks I realise that the alternator has its own voltage control,but do I need to remove any wiring ,mainly to the barrel regulator
You can see what to do here: https://lulis.org/2015/05/06/daynamator/
Thanks ,but the problem is the diagram shows for a 1946 car ,Since mine is a 1934 the voltage regulator ive been told is really a voltage cut off device and is completely different regulators than those in later cars Len
Can you identify the D, A and E connections? They mean Dynamo in, Ampermeter and Earth. This is universal and once you identify them you know everything you need to know. Looking at the circuit diagram at the workshop manual I see that they are clearly marked on your controler.
Thanks again will do Len
Checked the regulator connections,and they are as shown, no connection has D on it.The top left is marked SX down one and its A bottom left is AUX. The bottom one on right is E cannot see a D on any Started the engine for the second time since buying it ,after double checking the timing and it ran for 2 seconds and stopped checked points and electrics and found the coil has packed up .Tested it off the car and not a thing .Oh the joy of restorong Len
- DSCF0296.JPG (135.16 KiB) Viewed 30762 times
- DSCF0294.JPG (151.05 KiB) Viewed 30762 times
Hello thank for the references,but they are all for 1947 era cars which are different to my 1934 model.I haven`t seen any references to the older models,on the site you recommended Len
