Post
								by digcot65 » Sun Feb 28, 2021 11:22 am
			Congratulations,its supposed to be the joy of owning a classic,but can fray your nerves sometimes I`m still trying to cure wiring problems.Sometime in the past,someone did away with the solenoid in the headlamp,where one filament goes off or on , depending where the dip switch is .They then fitted a double filament bulb in both headlights,but both are on ,whichever position the dip switch is .So I`m replacing the wire from the dip switch to both headlights so It should work correctly .Now I`ve had the headlamp shells and reflectors back from being replated and can`t wait to see what the headlights are like.I remember when I first bought the car I tried them and they weren`t very good,due to badly tarnished reflectors  Len
						- DSCF0188.JPG (163.99 KiB) Viewed 7395 times
