1934 Rover 12 dash switches
Does anyone know ,how to remove the fog/pass light switch on the dash Ive managed to pull the dash forward enough to see the pass light switch and measure with a meter,but its faulty I cant see how to remove the switch Normally,there are two slots on the front chrome ring to turn and remove but not on this
Re: 1934 Rover 12 dash switches
is there a photo please Len?
Morning,I undid the dash,but could only pull it forward a couple of inched.So I was unable to see the back of the switch,I manage to get my meter probes onto it,which showed it wasn`t working .Strange,since its such a simple switch Len
- DSCF0176.JPG (165.68 KiB) Viewed 7176 times
I think you will find its secured by a brass nut behind the metal dash panel. Just a thought as it is just a simple switch, would spraying switch cleaner on the switch clean the contacts?
Thanks now I know I can try to clean or even get a spanner in Thanks Len
Since I have to try to undo the switch by feel,as I cannot see it properly,have you any idea what size spanner is needed.Rather than trying to get a spanner to fit blind Len
