Took my 1937 Fourteen Saloon out on the road for the first time, after reconditioning the engine (bought stripped, so no chance of a test drive!). But found the steering VERY heavy, I expected it to be heavy but not that heavy.
I’ve stripped all the linkage and king pins (all good) all joints are free moving. Admittedly the box requires reconditioning (nearly 3” free movement at the rim) and the box (bought as a replacement 6th Aug 2014 less than 300 miles ago) by a previous owner was completely void of lubricant when I got it, now filled with Penrite steering box lube.
Could someone with the same model please tell me how many revolutions of the steering wheel it should have, lock to lock. Mine has two full turns and (looking at a clock face) 25 minutes, so under 2.5 revolutions. But, with the drop arm removed I get THREE full revolutions of the wheel.
The Rover numbers on the drop arm and track rod levers do not tally with ’34 - ’40 spares book. The number on my drop arm is. 2R/9M/2. B. what's that from??
I think if the drop arm was shorter that would increase the ‘gearing’ giving more revolution at the steering wheel, or am I looking at things wrong.
Going by the spares book the whole steering assembly differs between 1937 an 1938, the only two years for this model! So I’m not holding my breath expecting to find all the correct parts!
BTW I can’t find a Rover number on the box, only the Burman-Douglas Pat. No. 3(5 or 8)1204 Would it be behind the box where it bolts to the chassis?
Eric
