p3 75 1948 front wing
moshe
Post by moshe » Tue Dec 25, 2012 7:28 pm
Hello dear friends,I need r.h front wing for my p-3 75 6 light r.h.d .Please correct me if I'm wrong thinking it's the same as for Rover 12 .Can some one out there check it up for me please ?
thanks Moshe .
Re: p3 75 1948 front wing
Post by 47p2 » Tue Dec 25, 2012 8:26 pm
Hi Moshe, The P3 wing is not the same as the 12hp from what I know. I would think you need to find a wing from another P3
jefflee
Post by jefflee » Fri Dec 28, 2012 2:09 pm
Hi, P2 wings have a bead aprox three quarters inch around the edge,exept the post war 10hp & P3,
there is also a slight differance to meet running board on saloons / sports saloons. thank Jeff.
moshe
Post by moshe » Sat Jan 05, 2013 8:08 pm
Thank you John and Jeff ,your both right ,P-3 wing is not the same as the p-2.I forgot the main diffrence:the p-2 has a cut in the front inner corner ,next to the rad. shell ,for the leaf spring to come out. P-3 has coil springs so the wing is "full".
Thanks ,Moshe.
