Hi all,
Does any one know where I can source the rubber seal that fits over the chrome headlight bar and cover the hole in the wing on per war Rovers?
Mine have given up the ghost and I'm struggling to find any.
Thanks as ever
									Pre war headlight bar rubber seals
				oilmagnet477
1932-3 Rover 10 Special, 1980 Series 3 Landrover
Re: Pre war headlight bar rubber seals
Hi Tony
Mike Couldry (Meteor Spares) is your man, I have had several sets off him over the years. There are actually two on each bar, an angled one that goes onto the wing side and a straight one that goes up against the cut-out semi circle hole on the edge of the chrome radiator surround.
Trust this helps
Cheers
Andrew McGovern
Trust this helps
Cheers
Andrew McGovern
				oilmagnet477
Thanks Andrew, will add this to the long list of things Mike has/is already supplying!!
Don't know why I hadn't tried him for these - guess I'm trying to spread the pain!
Must catch up soon, my 10 is very nearly ready to fire up again after major fun and games but Chris has done a fantastic job getting the 2 engines into 1 serviceable one so I have high hopes that we will be on the road before the end of May.
Hope all is well with you and thanks once again
Anthony
Anthony
