Radiator mascot Viking head two versions (?)
ThomasMoRo
Post by ThomasMoRo » Mon Jun 03, 2024 3:06 pm
I am still looking for a radiator mascot for my Twelver Sports Tourer from 1948.
I would prefer the Viking head but the version with the lower helmet.
Kühlerfigur Wikinger niedrig.jpg (30.81 KiB) Viewed 10957 times
More often you see the version with the helmet pointing upwards.
kühlerfigur wikinger hoch.jpg (36.92 KiB) Viewed 10957 times
I assume that these Vikings are very rare, aren't they?
Or can you buy them somewhere?
Re: Radiator mascot Viking head two versions (?)
Post by SHyslop » Mon Jun 03, 2024 6:13 pm
Mike Couldry should have replicas, the swept back ones being called the "Speed" pattern. Before fitting one, it is maybe useful to know that the bonnet sides are likely to catch on either version when the bonnet is opened if the Viking head is left in place. It can be a good idea to keep the Viking head for "show" and use the normal cap otherwise. Just a suggestion.
I have weighed what I know to be reproductions and what I think are originals. The copies are about 516 grams and the (presumed) original is 962 grams so I reckon the weight is probably a reasonable indication of whether you are buying an original or a copy. That's for the whole cap and base assembly, not just the head.
ThomasMoRo
Post by ThomasMoRo » Tue Jun 04, 2024 10:11 am
Many thanks for the explanations and tips.
Thomas
