I’ve got a bad coil. Looking for suggestions to replace. I am assuming a 3 ohm 12v would be fine but looking for feedback
Jason
1932 10/25 replacement coil recommendations
1932 10/25 Nizam
Re: 1932 10/25 replacement coil recommendations
What type of distributor do you have? 3 ohms means 4 A at the points which may be on the high side for it. P2 coils had 3.8 - 4.5 ohms . However, good chances are that a 3 ohm coil will be fine.
