window seals P2
MikeB
window seals P2
Post by MikeB » Tue May 13, 2014 7:47 pm
HI There
I am new to the Rover P2 and have a 1939 10 that is currently being re trimmed, I have noticed that there are remnants, or so it seems, of seals around the window frames to hold the glass tight in the door frame, Does anybody have any dimensions of these seals and the profile required ?
Re: window seals P2
Post by GOY189 » Tue May 13, 2014 8:17 pm
Try Woolies or Paul Beck. This may help http://www.woolies-trim.co.uk/p-1023-wi ... annel.aspx
The chief difficulty is likely to be finding the pan head screws that hold the old channel in. Good luck
MikeB
Re: window seals P2
Post by MikeB » Tue May 13, 2014 8:40 pm
Mike, thanks very much for the prompt reply, I will measure the glass thickness and the window frame gap and see if I can make it fit, I will keep you posted
Thanks for the Help
