rover 25 not starting
steven77
Post by steven77 » Thu Jun 09, 2011 5:46 pm
hi i have a rover 25 wreg been sitting for about a week now it wont start will turn over just wont start the egm is staying on when egntion is turned on and when turning over mileage flashes it is 1,4 16v wreg
cheers for any help
paul williams
Re: rover 25 not starting
Post by paul williams » Thu Jun 09, 2011 10:48 pm
Welcome to the forum steven77
I had a similar problem on an 800 a few years back, it turned out to be the battery. Have you checked the terminal voltage on your battery, maybe you have a substitute one? On mine I had to replace the battery and all was well.
Hope that helps
Paul Williams
1929 2litre Saloon
1934 P1 10HP
1951 Rover Cyclops
1974 P6 3500
1998 LR Discovery I
steven77
Post by steven77 » Fri Jun 10, 2011 9:27 am
thanks no battery fine there was a buzzing noise from wee black thing that sitts behind oil cap its attchet to injector thing but at end near air box
Post by 47p2 » Fri Jun 10, 2011 6:59 pm
Sounds like low voltage to me
steven77
Post by steven77 » Sat Jun 11, 2011 10:39 am
would that fling up egm light presst wee blavk box thing on bulk head sumeone said fuel cut of switch :?: it clickt when i presst it
when i try jump it egm staying on and mileage flashing :!:
