Rover P3 60 clutch drag?
blackhorse
Post by blackhorse » Wed Apr 27, 2016 11:37 am
I have a 1948 P3 60 and have had a total engine rebuild carried out, the clutch fitted is of the modern Borg & Beck type, selection of 1st & reverse is virtually impossible due to the clutch dragging - however it is fine whilst driving....
Has anyone any advice please?
Re: Rover P3 60 clutch drag?
Post by luli » Wed Apr 27, 2016 4:29 pm
There is still some residual friction left when the clutch lever is fully depresd. You can temporarily overcome that by first selecting third speed and then quickly shift to first. In this case, the synchromesh helps to stop the layshaft, enabling you to select first.
Post by GOY189 » Thu Apr 28, 2016 11:41 am
Has the B&B clutch been fitted recently? The conversion for a 75 is relatively straightforward and uses a Landrover part, but the conversion on the 60 needs a long withdrawal sleeve that has to be fabricated. Has yours been made the correct length?
Just a thought
blackhorse
Post by blackhorse » Sat Apr 30, 2016 5:58 pm
Hi & thanks, don't really know about any conversion procedure - do you know the details?
Regards...
Post by GOY189 » Fri May 06, 2016 10:34 pm
Full details are in the Rover Sports Register's Workshop manuals, Briefly, as the original clutch is a Rover Patent Clutch, you neeed to find the Borg and beck equivalent, a flywheel from an early P4 to take the different clutch and a new withdrawal sleeve. In the case of the 60, this has to be made up.
jp928
Post by jp928 » Thu Aug 04, 2016 5:34 am
My memories of the clutch withdrawal linkage on a P3 75 are not pleasant. I would check and see if these have been played with, or are not at factory settings - I went through the same issues with mine once.
jp Previously P2,P3,P4,P6,P6b, RR , Disco
