Hi everybody
Does anybody know where I can source the following parts for 1948 r0ver 75 p3 :-
track rod inner joints
universal joints
rear shock absorber
front brake flexi-hose
front o/side wheel bearing/kingpin
front n/side wheel bearing/kingpin
or are there substitutes that will fit
cheers
parts for 1948 rover 75 p3
Re: parts for 1948 rover 75 p3
Allways worth trying the clup spares dept first or Meteor spares http://www.thersr.co.uk/meteor-spares-ltd They have always managed to help me out in the past but for the brakes these might be worth a try http://www.powertrackbrakes.co.uk/index.html not had to use them but they seem to have a good range of brake stuff.
Wheel bearing are made to a standard size most car makers made the car to fit the bearings not the other way round so any bearing supplier should be able to help also some parts are common to the early land rovers so check out suppliers for them too if you have one out to show them they might be able to match it up, shock absorbers on the rear at least are a standard fitment (I used Morris Minor bottom bushes on mine last year so some of the shelf adjustables could be the route to go there but do check out Meteor spares he's easy to talk to and helpful with advice and has access to way more stuff than he lists.
Good luck Steve
Good luck Steve
Bernie Hurren
Scotts old rubber has a lot of gear as well I goy some gaskets and bushes from them.
http://www.scottsoldautorubber.com.au/R ... 948-49.htm
Good luck
Bernie
Good luck
Bernie
