Rover P3 Distributor
kartik
Post by kartik » Sat Dec 22, 2012 2:00 pm
I need to know how to secure the Distributor in a P3, is there a Clamp
or some other fixture to secure the distributor.
can any one please upload picture of the distributor/engine area.
thanks in advance
Kartik
Re: Rover P3 Distributor
Post by lakesrally » Sat Dec 22, 2012 4:53 pm
Hi, there is a clamp but I am away from home at the moment and cannot take a picture for you. I'm sure someone else can post a picture before I get home at the end of next week, if nobody has posted by then let me know and I'll take a photo for you.
Post by 47p2 » Sat Dec 22, 2012 10:42 pm
Stewart, is it the same as the P2?
Post by lakesrally » Sun Dec 23, 2012 7:16 am
Hi John, I'm not sure to be honest, if you post a picture I can tell you if it looks anything like mine.
moshe
Post by moshe » Tue Dec 25, 2012 7:36 pm
Hi ,the dist. on p-3 is diffrent from the p-2 it has vacum advance .
Moshe from Israel.
Post by 47p2 » Tue Dec 25, 2012 8:25 pm
The P2 has an alloy spacer between the engine block and the distributor, at the top of the distributor there is a clamp which can be seen in the images. This clamp has an adjustable thumbscrew for advancing/retarding the ignition without undoing the clamp. Hope this helps, maybe Stewart can confirm if the P3 is the same set up
Post by lakesrally » Thu Dec 27, 2012 7:20 am
No, it's different. I hope to be home tomorrow night but the P3 is not at home. I'll try to get to the barn it is in over the weekend and take a picture.
Post by lakesrally » Sat Dec 29, 2012 2:30 pm
Hi Kartik, here are three views of the clamp in-situ on the car. To give you any more detail will require me taking the distributor and clamp off the car, which I will do if required but I'd rather not as I am bound to end up with problems getting the timing right again.
kartik
Post by kartik » Sat Dec 29, 2012 2:53 pm
Stewart
Thank you so much, I hope we would manage with these pictures.
Kartik
