Page 2 of 2
Re: 1949 P3 Restoration help!
Posted: Tue Jul 08, 2014 8:14 pm
by classicclara
Wow Mike - at £3.2K for a complete refit to your car - £3000++ just for headlining seems even more ridiculous!!
Lowest estimate for headlining so far is £1000. I've also been quoted £1500 per week for seats & headlining and it'll take 3 weeks work. Can't afford £4500 + materials! Where are these prices made up from?!
![Shocked :shock:](./images/smilies/icon_eek.gif)
Posted: Wed Jul 09, 2014 6:16 pm
by classicclara
Hi All
Have received a comprehensive list from my mechanic of what wants doing. I know it's difficult but could any of you estimate how much you would be willing to pay for this work below as my mechanic's estimate has increased by £2500 from what he originally said (he had looked over the car). This is purely for mechanical work not the headlining or seats etc.
Rover 75 P3
1. Horn inoperative
2. Gauges various electrical problems
3. Sunroof plated over/ no internals
4. Drivers window mechanism broken (repair or replace)
5. Rear lights inoperative
6. No tools in tool tray
7. Clutch problem Labours 10 hours
8. Seats poor condition (sugest good feed)
9. Radiator leak Labour 4hours - radiator £360.00 new/recon
10. Engine runs but rough - needs service plugs, leads oil need changing etc
11. Headlining?
12. Poor body repairs & paint work rough
13. Sills- holed & corroded fixing for running boards (scructual part of body)
14. Brake pipe to near side front corroded & need replacing
15. Rear chassis holed & corroded to rear spring hangers & movement in bushes
16. Battery missing
17. Lower & upper wishbone bushes perished & worn
18. Rear spring bushes perished & worn excessively
19. Rear bump stop missing
20. Battery tray corroded
21. Oil leak in gearbox taleshaft
22. Rear X member bent
23. Front anti-roll bar bushes perished
24. Windscreen seal perished & disintegrated
26. wheel cylinder nuts loose
Thanks guys!
Posted: Wed Jul 09, 2014 7:42 pm
by classicclara
Does this sound right for welding work?
1, remove running board section and strip out inside 2.5hrs
2, cutting off old brackets and taking patterns 1.25hrs
3, brace up body 1hr
4, cut out sill section (the entire lengh is corroded) 4hrs
5, fold new sill in 1.2mm in 2 sections roll curve to shape spot weld together 7hrs
6, weld in new sill completely to floor section 6hrs
7, weld in and make good to b, c and d posts 5.5hrs
total 27.25 hrs per side
Posted: Sat Jul 12, 2014 7:38 am
by P3Steve
Are you not able to tackle any of the work your self say starting with something simple like making up the battery box for example then just paying to have it welded in place as often its the fabrication that takes the time and thus money, While I realize major structural work can not always be tacked by many of us there seems to be lots of jobs on the list you could have a go at your self, the sun roof tor example your welcome to come and look at mine to get an idea of how it all goes together and take photos as I guess your not to far away judging by your original post. I guess I'm lucky as I cut my teeth working at a Leyland garage back in the 1970s at a time when mechanics still repaired cars not just swapped parts but on saying that there a fairly simple machine realty and if you take your time there quite easy to work on. Remember restoration is like eating an elephant small bite at a time. Regards Steve
PS. just spotted your pm and have replies Steve
Posted: Sat Jul 12, 2014 4:10 pm
by robby
classicclara wrote:Does this sound right for welding work? <snip> total 27.25 hrs per side
As has been said previously about the seats, it`s difficult to assess welding without seeing it properly, however, from the times and descriptions you have given, then I don`t think it`s far out it`s certainly sounds like a good weeks work and around £1200 I`d say
