Front hub seals
Posted: Mon Jan 31, 2011 7:24 pm
by Axle
Hi, can anyone tell me the NA part number of the front hub seals for my 1938 12 p2 and would they be the same as the auntie range, cheers.
Re: Front hub seals
Posted: Sat Feb 05, 2011 2:20 pm
by GOY189
Hello, Needed a little research to answer this one.
All models 1936 to 1960 (includes all drum braked P4s) used Rover part number 03429 that superceded to 235986. The Payen equivalent number I understand is NA239. (For intrerest Disc braked P4s and I suspect P5's use a thicker seal- NA525).
Full instructions for stripping, replacing and adjusting the hubs are in The P2 Workshop Manual published by the RSR. Usual Disclaimer applies.
Mike Maher
