The restoration of my 1947 12hp has been going well Engine back in and fired up - phenomenal oil pressure (I'll have to get that sorted!), steering, brakes and suspension all sorted. On the whole going well.
But....
The engine was fitted with new engine mounts and a new gearbox/freewheel housing cradle rubber. So far, so good. The engine /gearbox unit has gone back to where it was as witnessed by the marks left by the two old rubber pads on the aluminium casting. But, when I fitted the remote housing and speed change lever my troubles started. Firstly, the bottom of the lever was fouling on the freewheel casing, and secondly the neutral position appears to be too far forward so reverse cannot be selected because the lever fouls on the part of the gate that forms the guide for the first and second gear selection. A further issue is the the reverse stop washer also hits the top part of the support bracket - this prevents selection of fourth gear.
When I last used the car and before I took it all apart, the gear selection was faultless. I have checked that all gears can be selected by using a bar on the selector bars they all slide freely and snap into place cleanly. In order to lift the gear lever I have fitted 1/16" shim under the four selector mounting screws (Item M22 on page F28 of the RSR Workshop Manual). There was no shim fitted originally. The car suffered some quite severe damage whilst being stored but I am not aware of ant damage/distortion of the speed change mechanism.
Any suggestions would be welcome.
Speed change Remote Control
AdrianGoodyear
Return to “Wilks' cars P1 and P2, thats cars up to 1947”
Jump to
- General Discussion
- ↳ RSR Discussion
- General Information
- ↳ Forum dos and don'ts
- ↳ Adding Pictures
- ↳ New members
- ↳ Rovers Spotted
- ↳ Meetings, Rallies and Events
- ↳ I want and I 've got..
- Rover Vehicles
- ↳ Rover History
- ↳ Rover bicycles and motorcycles
- ↳ Archive
- ↳ Veteran/Vintage Rovers
- ↳ Archive
- ↳ Wilks' cars P1 and P2, thats cars up to 1947
- ↳ Archive
- ↳ Early post WWII, P3 the original Rover 75 and 60
- ↳ Archive
- ↳ Rover P4, the next 75 and all the variations
- ↳ Archive
- ↳ P5, straight 6s and V8s
- ↳ Archive
- ↳ P6, rover 2000s and 3500s
- ↳ Archive
- ↳ SD1, Rover with BL, what a combination
- ↳ Archive
- ↳ Rover 800, all doing a sterling job
- ↳ Archive
- ↳ Rover 100, 200, 400, 600, 25 and 45 inc Tomcats and Dropheads
- ↳ Archive
- ↳ Rover 75, the latest and last
- ↳ Archive
- ↳ The Specials, Maurauders,convertibles,Pininfarina,Graber, Kitcher and ...
- ↳ Archive
- ↳ 4WD, from pre-production to latest RR
- ↳ Archive
- ↳ And those not mentioned above ..
- ↳ Archive
- RSR The Rover Sports Register
- ↳ Club Information
- ↳ Freewheel, comments and contributions
