Fuel reserve unit for P2 12hp tourer
Post by David2021 » Mon Mar 14, 2022 10:54 am
Does anyone know for certain what the two pick up pipe lengths are? They are measured from underneath the flat face of the unit.
The 12 tank is different size /capacity to the 10 & 6cylinder cars.10.5 gallons against 10 or 11.75
Lucas 78000 is 9"+ ? & 11.7/16" (I cannot decipher the poor copy!)and that, logically, appears to be for the larger tank
78001 7.3/4" & 10.1/2"
I suspect it is part 78001 for the 12hp. Luli suggests 8" in his excellent "how to do it", but I was not clear which car this was, nor which pipe, nor where he measured from!
HAD501
Re: Fuel reserve unit for P2 12hp tourer
Post by HAD501 » Sun Mar 20, 2022 3:06 pm
Hello David
I've just measured my spare unit and the lengths are 9.9 and 10.9 inches approx. (15/16 in old units). My reading of the parts lists is that all models use the same reserve tap except 10 saloon and coupe. I did have a 6-cyl tank ages ago and from memory it was the same height and width as a 12 tank but deeper front to back (brain cells could be letting me down here, of course). I got a better tank for my 12 a while ago but still have the old leaky one. The sides and top are not too bad - it's the much bodged bottom that's the problem. If you think it might be of use to you, it's yours!
Best of luck, DaveM
HAD501
Post by HAD501 » Sun Mar 20, 2022 3:16 pm
Should have said measurements are relative to the mounting flange!
