tappets
tappets
Post by digcot65 » Sat Jan 22, 2022 10:42 am
I will be fitting the head back onto my friends P2 soon What is the correct tappet setting ,it says 5 thou when warm ,but what when cold.Alao is 5 thou still the best setting when warm Len
Re: tappets
Post by digcot65 » Sat Jan 22, 2022 8:39 pm
I may have got the tappet setting amount wrong ,but any advice please. Also when fitting the rocker assembly back on the head I believe the shaft should be in a certain position Is this correct Len
Re: tappets
Post by luli » Sat Jan 22, 2022 10:27 pm
Re: tappets
Post by digcot65 » Sun Jan 23, 2022 10:17 am
As regards to the rocker shaft does it have to be fitted ,yo align oil feed holes in a certain position Len
Re: tappets
Post by luli » Sun Jan 23, 2022 12:36 pm
7 o'clock
Re: tappets
Post by digcot65 » Mon Jan 24, 2022 1:59 pm
Thanks Luli, I noticed that the holes in the rocker shaft are at 9 o`clock which I can alter to 7 pm .The hole in the actual tappet is at 3 o`clock is this right. I would have thought they should line up. As I said this isn`t my car ,I`m overhauling the head for a friends car so Im not familiar with this model
