Oil pressure was a solid 45 at 60 and water temp never went over 170F. Fuel consumption not checked, but on past experience not much better than 22mpg....No oil nor water used.
Tail pipe is very black, so suggesting running rich. As far as I can see there is not a means of weakening the mixture (except on the slow running, and the tick-over is very smooth) Plugs suggest the same....any advice? No popping & banging on the over-run, just a rather "rich" smell from fumes coming into the car (This time going DOWN Fish Hill !)
Off to tour the Peak District next week, confidence increasing!
Timing is untouched apart from checking the points...what advice on advancing the "octane adjuster? currently on 0. I suppose I should go back to square one & check it, but I am loath to do it before the tour next week....ain't broke...
