Re: Tyre rubbing
Posted: Thu Sep 26, 2019 11:24 am
Rob,
With regard to measurements, my earlier advice was in relation to the original concern that the near side inner wing was closer to the tyre than the offside was. As such you need to be checking that the axle is equidistant from chassis to hubs and that the body is also equidistant from the chassis to key points like inner wheel arches. Then you will know if the problem is, say, movement in the springs or perhaps a shift of the body on its mountings.
Unless your car has been restored at some point it is probable you will find wear in spring bushes and wheel bearings, as previously discussed. However, if this is not excessive, you may risk diverting your attention from the real problem and end up undertaking a lot of costly remedial work that results in your car being laid up unnecessarily for a lengthy period.
Just a thought. There are too many lovely old cars that have ended up off the road and I know from personal experience that even the most interesting of Rovers struggle to find a home once they are in that situation.
