				Help, how does my 14 dash come out?
				Posted: Tue Sep 15, 2015 3:03 pm
				by Arewethereyet
				Hi all, my ignition switch is spinning round and the solenoid wires adrift! I've removed the 4 nuts that appear to hold the instruments into the dash but the cluster is still being held. How do I get the cluster out without removing the whole dash!
				Re: Help, how does my 14 dash come out?
				Posted: Fri Sep 18, 2015 8:50 pm
				by GOY189
				The ignition switch is held in by a wire clip that is fastened with a small nut and bolt.    Loosen the bolt, slide the clip backj and you should be able to  pull the ignition switch out without  removing the dash
 hope that this helps
				Posted: Sat Sep 19, 2015 10:56 am
				by Arewethereyet
				Many thanks Mike, that's it sorted.
