				Rear engine/gearbox mount
				Posted: Mon May 18, 2015 2:30 pm
				by RovingJoel
				Hello,
Can anyone tell me whether it's possible to change the rear engine/gearbox mount (the big rubber block) without removing the gearbox entirely? The car is a '37 model 10hp saloon.
Many thanks.
				Re: Rear engine/gearbox mount
				Posted: Wed May 20, 2015 6:49 pm
				by Vince
				Yes.  I have done it by just talking the weight of the box on a jack. All my floors are out at present which I'm sure made life easier.
				Posted: Fri May 22, 2015 10:09 am
				by chris dancey
				Hi Joel,
Remove the four large rear support securing bolts and the retaining strap, then lift the gearbox with a jack, the support should come out easily backwards. When refitting the strap, there needs to be a small space between the gearbox and the strap to allow the gearbox to move, but secure, an old hacksaw blade was the past method of gap measurement.
				Posted: Fri May 22, 2015 12:50 pm
				by RovingJoel
				Many thanks Vince and Chris,
I thought it was probably possible. I was trying work out how much time I needed!
I get the dreaded clutch judder if I'm nothing but very careful and while I realise I probable will have to get to the clutch to check the toggle lever adjustment and the plate for signs of oil, I thought starting with clutch cable/compression rod and engine mountings seemed logical.
Thanks again.
