				Brake Rods Binding
				Posted: Wed Mar 11, 2015 6:48 pm
				by RobHomewood
				I was under the back seat doing some wiring (39 14 DHC) when I noticed that the main front to back brake rod is binding on the chassis cross member ( over) and the rear axle (under). In fact it is bent. Would this be just because the car is up on axle stands and the wheels/rear axle are hanging abnormally low? The parts list does not show the brake rods in context so I am not sure if the rod is routed correctly. Would the garage have had to remove the brake rods when they were removing/refitting the diff which has been refurbished recently? The car hasnt been on eth road since aprt from a couple of miles home. Your advice would be greatly appreciated before I hit the road again.
				Re: Brake Rods Binding
				Posted: Wed Mar 11, 2015 8:20 pm
				The rear suspension of Rover P2 is under-slung, which means that when the chassis, and not the wheels, is supporting the car, the rear axle will "go down" as far as it can. There should be rubber blocks to act as "down limiters" that limit how low it can go. Are yours O.K?
See some pictures here:
http://wp.me/pXLKy-Ll
				Posted: Thu Mar 12, 2015 12:30 pm
				by RobHomewood
				Thank you Luli for your ever helpful blog link. Alas you are quite right- when I looked I could see no sign of the buffers at all- they were history and the axle was sat straight onto the chassis! Only when I let the car down off the axle stands could I see the minimal remains of the buffers.[img
][/img]
Interestingly they seem to have been fixed on with split pins (just discernible under curve of frame) direct to the chassis and no bracket as you show. The parts list seems to confirm this as the original arrangement as it describes the split pin fixing to the 'chassis frame OR bracket'
Now to find new ones!
				Posted: Thu Mar 12, 2015 1:17 pm
				by Chris C
				You should be able to get replacement top & bottom rubber bump stops from Meteor Spares Service @ Nottingham
Tel:0115 9811222  Email:
meteorss@hotmail.com
