windscreen replacement
Posted: Fri Jan 30, 2015 6:34 am
				Hi All
About to start replacing my windscreen on my P2
After drilling out the holes that hold the two strips of metal together and removing the frame to release the glass, I sent the frame off off for plating, however now I am ready to replace it I need to get the two half's of the screen to lock together again via the strips with the tapped holes in them, now I realise I should have had the oversize holes plug welded before I sent the screen to the platers !
I have tried chemical metal in the elongated holes to fill them and then to drill them out, however there does not seem to be enough adhesion around the holes to hold the chemical metal in, and when drilling the new holes it breaks up, I suppose I could have the holes plug welded after chroming, however I feel that this may ruin the plating and cause more issues
Has anybody repaired these holes in the screen half's before ? and if so have you got any tips and tricks before I decide which way to go, is filling the holes with brazing possible ?
Thanks for any help
Thanks for any help
