Side panel question
MikeB
Side panel question
Post by MikeB » Sun Nov 09, 2014 1:12 pm
Hi I am tidying up me rover over the winter months and was wondering what the is the purpose of the channel piece on top of the bonnet side panel is for it is held on by lots of screws ( The wrong ones at the moment, see picture) should this area have a fabric strip on it to stop the bonnet tops rubbing on the side panels ? is this what the screws are for ?
Appreciate any help on this, thanks
Chris C
Re: Side panel question
Post by Chris C » Sun Nov 09, 2014 1:57 pm
In most cases there is a narrow strip of black bonnet lacing trapped between the metal
strip and the top edge of the panel. It very slightly protrudes over the edge, so that it
gives a good seal when the bonnet top is closed. The screw heads are positioned correctly
on the top of your side panel.
Rgds, Chris C
1939 - Rover 14 Saloon
Rover Sport Register
1939 - Rover 14 Saloon (P2)
1975 - Rover 2200 Saloon (P6)
Post by luli » Sun Nov 09, 2014 4:03 pm
You can see some pictures here: http://wp.me/pXLKy-1ic
The webbing strip makes the top of the side panel more flexible and reduces rattle. I had got mine from Scott old auto rubber.
MikeB
Post by MikeB » Tue Nov 11, 2014 6:13 am
Thanks both for the information , I have no found some pictures on the forum of this bonnet lace, and will track some down, I guess that's why I have paint scuffs on my bonnet sides !
Thanks for the help
Chris C
Post by Chris C » Tue Nov 11, 2014 7:37 am
If you'r going to the Classic Motor Show @ NEC this weekend, then Woolies and various other trim suppliers
will be there.
Chris C
Post by 47p2 » Tue Nov 11, 2014 8:06 am
The webbing should be lubricated with oil every now and then according to what I've been told, this stops it drying out and going hard it also helps preventing rust where it rubs against the paintwork and provided a little more weatherproofing...So I was informed
MikeB
Post by MikeB » Sat Nov 15, 2014 1:33 pm
Thanks all for the reply, went the NEC classic car show and picked some up from wollies
Whilst there
