Engine removal via the manual
Posted: Mon Nov 03, 2014 7:00 am
				Hi
Just removed my engine on my P2 so I can paint the bulk head and chassis, and overhaul the engine, I decided to use the procedure in the manual to remove the engine which seems straight forward, however when following the instructions I felt that some of it is unnecessary and makes things more difficult than it needs to be. Once I had the engine loose it was quite obvious that the crankshaft pulley for the dynamo belt needs to be removed to allow the engine to come forward enough to allow the studs on the bell housing to move out of the holes on the flywheel case, after a lot of pulling and tugging I managed to get the engine out, I won't' be refitting it this way !
Does anybody have any tricks for easy engine removal/ replacement to share ?
