Hope you've all had a good summer of Rovering!
The picture is of my rear off-side spring shackle. (1937 model 10hp saloon.)
I have a query regarding the lower nut. I think it should be on the inside of the shackle because the nearside shackle lower nut will sometimes foul on the rear wing. I recently saw another 10hp saloon and this had the lower nut on the inside of the shackle. I realise I can't simply reverse the bolt because of the casting of the shackle which acts as a retainer for the bolt head to stop it turning. So my question is, can I simply turn the shackle round or is it likely that the springs are on the wrong side? Are they handed?
Many thanks
Joel
 [/URL]
[/URL]
