1934 Rover 12 Steering
Post by digcot65 » Fri Jun 25, 2021 1:17 pm
Im just finishing the restoration hopefully and took the car round the block for the first time a couple of days ago .The steering wandered a bit so Im having the tracking checked next week.I had the steering box rebuilt at a cost of £900 in November and I checked the free play on the wheel,before any movement is detected on the drop arm and it measured nearly 50mm which to me sounds a lot for what is virtually a new box .How do members feel ,I contacted the firm who rebuilt it for their comment Len
Re: 1934 Rover 12 Steering
Post by luli » Fri Jun 25, 2021 5:21 pm
This is quite normal and within specs. Make sure that the angels are correct especially the castor which should be positive and far more tha what Rover specify, say 7 degrees.
See here what it does for driving (about the same free play on the steering rim):
https://www.youtube.com/watch?v=IYm7XEi50y0
Post by digcot65 » Sat Jun 26, 2021 9:37 am
Thanks, the video shows the car to be travelling at a fair speed,without the driver fighting the steering.How much of a job is it to alter the caster angle on a 1934 Rover 12
Post by digcot65 » Sat Jun 26, 2021 9:48 am
Sorry I forgot to add,if the caster angle needs altering,is there a known size of shim to give a certain angle I could have a wedge plate made,if required once I know what size it is .I realise from previous old cars ,there is always play in the steering,but as long at it centres to a straight line ahead that`s the main help.Len
Post by luli » Sat Jun 26, 2021 1:13 pm
Usually it is enough to flip the wedge so that the word "front' will point backwards. See more here:
https://lulis.org/2019/11/26/castor-take-two-2/
