1934 Rover 12 IDENTIFY A PART
Post by digcot65 » Tue Apr 20, 2021 10:47 am
Found this is the engine tool box ,has anyone any idea if its off the Rover.As you can see it split in two and there are three prongs on the rear Len
Re: 1934 Rover 12 IDENTIFY A PART
Post by luli » Tue Apr 20, 2021 7:48 pm
It is part of the traficators control, on the steering column, just below the steering wheel. No 97
Post by digcot65 » Wed Apr 21, 2021 9:20 am
Thanks I knew someone out there would have the answer I wondered if it was for the lower part of the steering column to seal the hole,where it comes through the bulkhead So I was only a metre away Len
